Author Topic: Control Z scale by texture  (Read 5212 times)
Richard Birket
« on: June 11, 2013, 12:43:00 pm »
I am trying to control the height (z-scale) of some rods in an FP object by using a simple texture but am not sure how to go about it. Hopefully the attached screengrab will explain. If I can't control the z-scale by texture, is there any way I can use a texture to displace the rods in the z axis?
Kind Regards,
Rich
www.blinkimage.com
Re: Control Z scale by texture
« Reply #1 on: June 11, 2013, 01:18:44 pm »
Please, be sure there is a Surface assigned to Forest. The surface also must include UVW coordinates for the map channel defined in Transform->Scale properties.
Richard Birket
« Reply #2 on: June 11, 2013, 01:21:53 pm »
Thanks - I will give that a try. I was just using a rectangle rather than a surface.
Kind Regards,
Rich
www.blinkimage.com
