Author Topic: Convert to instances  (Read 11396 times)
FM3996
« on: October 19, 2010, 06:19:56 am »
I've been trying to find a way to convert a forest pro setup to a bunch of instanced meshes. I realize I can convert to an edit mesh, but these obviously get huge. It would great to be able to convert to a single mesh for each geometry and an instance per scattered tree. I believe MultiScatter has a function similar to this.
Is this possible? If not does it sound like something you would contemplate for the future?
Simon
Re: Convert to instances
« Reply #1 on: October 19, 2010, 07:31:57 am »
It can be done with the Forest Tools utility. You can find it in the Utilities Panel:
http://www.itoosoft.com/forestpack/reference/tools.php
FM3996
« Reply #2 on: October 20, 2010, 08:01:55 am »
Awesome, thanks. It looks like that will work perfectly.
When I was looking for this I searched in CHM help for anything referencing "instance" and nothing showed up. Turns out that if I search for anything, nothing ever shows up in the search results. Just looks like the search function in the CHM is broken.
« Reply #3 on: October 22, 2010, 12:03:03 pm »
Yes. The CHM help is a very old format with many problems. We like to replace it by a online help system with search options.
DIMITRIS
« Reply #4 on: October 22, 2010, 02:15:01 pm »
Also a modern PDF would be great
I will sign it only if it is a piece of art!
