Forest Pack => Forest Pro (*) => ForestIvy => Topic started by: FC2603 on February 11, 2025, 07:59:26 pm
Title: Copy ForestIvy
Post by: FC2603 on February 11, 2025, 07:59:26 pm
Is it possible to make a copy of a ForestIvy object? When I do the copy has no geometry.
edit: Sorry, just realised there's a ForestIvy board that I should have posted this in.
Title: Re: Copy ForestIvy
Post by: Michal KarmazĂ­n on February 12, 2025, 09:04:23 am
Copying ForestIvy objects depends on the setup. If you're using the Grow without Baseline option, you can simply copy the object and place it where needed. However, if a baseline is used, you should first Export it, move it to the desired location, and then Import it again into the copied ForestIvy object. If you're using Surface Object(s), keep in mind that they also need to be copied separately, as they are not embedded within the ForestIvy object.
Post by: FC2603 on February 12, 2025, 09:39:26 am
Understood, thanks.
