Author Topic: Foest Object doesn't load with scene  (Read 4601 times)
Michael Betke
« on: March 20, 2019, 11:32:29 am »
I still have a strange problem. Sometimes when I load up a scene with a forest inside, some forest objects get loaded and some not. The "F" symbol is only shown. I have to select it plus go to "modify" tab. Then the point clouds show up.
Furthermore the Density is set from "Full" to "Dense". I definitely set it properly to "Full" because I did a render with it the day before.
Using Forst Pro 6.1.7 with Octane 2018.1 and 3dsmax 2019 latest SP.
Re: Foest Object doesn't load with scene
« Reply #1 on: March 20, 2019, 12:11:40 pm »
Hi Michael,
Sorry to hear, you're facing these troubles. It sounds like the issue reported in the "FP instances disappearing when reopening scene" thread. Are you using the General > Presets feature? If you'll be able to reproduce it on a minimal scene, which you can send us, it would be great. Thanks in advance for any further comments on this issue you can share with us.
Michael Betke
« Reply #2 on: March 20, 2019, 08:49:32 pm »
I use a general-preset named "default" to have it as a start when creating a new forest. I set the "dense" map as default there too, plus some translation values. But in all cases I edit this default preset further.
I will sent scene when I run into the problem again.
Michael Betke
« Reply #3 on: April 17, 2019, 08:46:19 pm »
I would like to follow up on this one.
I need to batch render 20 files which are prepared and the Production render stops because I get a pop-up with the Forest error.
Really in need of a solution to be able to render overnight without errors.
