Author Topic: None flat grass  (Read 4831 times)
Bobby Parker
None flat grass
« on: November 05, 2014, 04:24:38 pm »
I have a plane with a noise modifier. I have my grass looking good, but on the high points of the plane, the grass isn't covering it. How do I fix this?
Re: None flat grass
« Reply #1 on: November 05, 2014, 04:39:09 pm »
You probably need to update the surface in surface roll out:
Re: None flat grass
« Reply #2 on: November 05, 2014, 04:46:31 pm »
Yes, Rokas is right. The Forest object will adapt perfectly to your uneven surface as you can see on attached screenshot. Just please double check the surface is listed under Surfaces rollout and it's updated - I recommend to thick the Auto option to update surface data automatically.
Kind regards,
Bobby Parker
Re: None flat grass
« Reply #3 on: November 05, 2014, 11:40:05 pm »
There wasn't anything in the Surface rollout, so I added it and it worked, thanks!
