Author Topic: One FP version on two different 3d studio versions.  (Read 17749 times)
swavec
« on: July 04, 2025, 01:57:51 pm »
Im installing FP and there is no choice for what MAX version install to.
It installs to 2022 ignoring 2025 version. Repeating installation process doesn't change anything.
Is it possible to have double installation of FP? Haw to choose MAX version?
Thank You
Re: One FP version on two different 3d studio versions.
« Reply #1 on: July 04, 2025, 02:16:44 pm »
There is no need for any special process - our plug-ins support multiple 3ds Max versions, and the installer should handle the installation process automatically. It might be that for some, 3ds Max 2025 isn't detected by the installer. When installing, in the Select Installation Type window, please check the Advanced Installation option - that will enable the selection of versions that aren't "detected" (in this case, 3ds Max 2025).
I hope that helps you, and please let us know if everything is working fine or if you are still facing trouble with it. Thanks in advance and have a great day.
swavec
« Reply #2 on: July 07, 2025, 08:07:12 am »
Found it.
I thought it was section to choose what parts of FP to install.
Thank you
