Author Topic: Custom Libraries  (Read 3329 times)
FC2603
Custom Libraries
« on: September 21, 2018, 07:48:02 am »
Just went to use the tree/plant library that I'd set up only to find that the library has disappeared since updating. Is there any way to retrieve it? I spent a long time adding individual trees and billboards!
Laubwerk tree library has gone too. I saw the suggestion to back something up in the registry but I've already updated, I take it it's too late now?
Re: Custom Libraries
« Reply #1 on: September 21, 2018, 09:18:55 am »
Your created library should still be in Your hard drive.
Look for index.xml file where You stored Your library.
Once You find it. Add Parent folder to Library Browser:
Doing these steps should restore Your library.
FC2603
« Reply #2 on: September 21, 2018, 07:53:08 pm »
Thanks for the reply. No index.xml on any of the drives on my computer. I can only assume I lost it when I changed to an SSD about 6 months ago. Could have sworn I'd used that library since then!
