Author Topic: using forest color with objects  (Read 3433 times)
mitviz
    • mitviz
« on: June 14, 2016, 06:15:29 am »
i have a scene with some people and suitcases but cannot get the colors to randomize with forest color, anything am missing
Professional architectural renders
Re: using forest color with objects
« Reply #1 on: June 14, 2016, 10:51:04 am »
Would you mind to describe more in detail your scene set-up? A screen-shot of the Forest Color map configuration would be handy too. Take in mind, in case you're using proxies, that as mentioned in our on-line reference guide:
"To use Map and Tint by Element, you must use VRay or Mental Ray and standard meshes as Custom Objects, other type of objects as proxies are not supported."
If that's the case, setting the Variation slider to Item should fix it.
Also, please feel free to send us your scene to check it here.
mitviz
    • mitviz
« Reply #2 on: June 14, 2016, 02:36:48 pm »
hmm the forest color map is all default, i tried by item and by default, so i made no other changes, its the first time i am using it
mitviz
    • mitviz
« Reply #3 on: June 14, 2016, 07:46:57 pm »
no news?
« Last Edit: June 14, 2016, 07:48:34 pm by mitviz »
mitviz
    • mitviz
« Reply #4 on: June 17, 2016, 08:07:33 pm »
made another simple test with a blank scene, and some balls any reason why it shouldn't work like this? just wondering how to get it going but its not working
mitviz
    • mitviz
« Reply #5 on: June 17, 2016, 08:14:00 pm »
ahh so you have to be using forest scatter to use it? just tried and its the only way to actually get it to work, would be useful if it works without forest scatter
« Reply #6 on: June 19, 2016, 11:07:32 am »
Yes, at present Forest Color only works with objects that are a part of a Forest Pack object. If it helps there is a script that can be used to add objects to FP so that Forest color could be used. You can get it here: http://forum.itoosoft.com/index.php?topic=2929.msg12480#msg12480  there's also a version that retains any instancing here: http://forum.itoosoft.com/index.php?topic=2929.msg14392#msg14392
Many thanks!
mitviz
    • mitviz
« Reply #7 on: June 19, 2016, 01:02:46 pm »
Thanks!
