Author Topic: Projection issue  (Read 2893 times)
TK1355
Projection issue
« on: August 17, 2016, 12:32:19 pm »
I have an issue with FP :
I create a closed line to project a forest on an object
When i move the line on Z axis, the forest moves on his surface, so i have projection problems because the forest doesn't fit exactly with the aera projection.
Thank you for your help
Re: Projection issue
« Reply #1 on: August 17, 2016, 12:56:44 pm »
Would you mind to provide us more details regarding these troubles (some screen-shot(s) would be handy)? Moving the spline on Z axis used as the Spline Area shouldn't affect the distribution and I would suggest you to double check local coordinates of involved objects. Please feel free to send us your scene to check it here.
TK1355
« Reply #2 on: August 17, 2016, 01:01:58 pm »
Thank you for your fast repply as usual.
I sent you the scene by mail.
Thanks for your help.
« Reply #3 on: August 17, 2016, 01:40:19 pm »
Such behaviour is caused by the orientation of local coordinates of used surface "Plane001" - to avoid it I would suggest to apply the Reset XForm utility over that surface to reset its local coordinates & scale. Attaching comparison between Forest objects over surface with rotated local coordinates and after reset.
TK1355
« Reply #4 on: August 17, 2016, 04:07:44 pm »
Hi, thank you for your reply,
It works on the test file I sent you, but the problem stills the same on my project file.
I sent you a new file.
For example when I move the Line 009 on the z axis, the FP gravel is moving on the Plane 001 (the plane is a editable poly).
The reset Xform utility reset doesn’t work for this case.
Thank you for your help.
