Author Topic: Inserts of Object in the scene and also on the Zero point of the scene  (Read 8565 times)
3d-labor
When I fill up my scene with trees and other assets with Forest Pack one example of every asset is visible on the Zero point (0,0,0) in the rendering, but not in the viewport. Once I had a solution for it, but I sadly forgot it. Does somebody has a solution for it.
« Last Edit: July 21, 2019, 10:02:12 am by JG1281 »
Workstation: i7-3930K @ 3,92GHz 16 GB RAM, Nvidia Quadro P4000, Win7/64 Prof.
Rendernode: AMD Threadripper 2950x@ 4,10 GHz 32 GB RAM, GeForce GTX 550 Ti, Win 10 Prof.
Autodesk Building Design Suite Premium 2019, VRay Next, Cup of coffee...
Probably You have "Render Hidden Geometry" option turned on:
I hope disabling it helps. If not please send us Your scene and we will check it.
You can turn off "Renderable" in Object Properties for all the assets.
Both FP and RC have a nice feature to override this so even if "Render Hidden Geometry" is checked, assets will not be rendered.
Best Regards
« Last Edit: July 21, 2019, 12:26:28 pm by Dragan »
3d-labor
Thank you both. Probably I hit the "Render hidden" button accidently.  I work with Forest Pack since several years but it never happens before. You saved a lot of my time!
