Author Topic: Grass on a slope  (Read 5256 times)
Bobby Parker
Grass on a slope
« on: December 19, 2014, 12:23:21 am »
When I add grass to a slope I get strange results.  Obviously, after you see the image, there has to be a workaround.
Re: Grass on a slope
« Reply #1 on: December 19, 2014, 10:11:41 am »
Actually, because of the uploaded image size, it's hard to say what's happening. I would suggest you to check your Direction settings under Surface tab (probably is set to 100). In case of large clumps I would recommend you to set it to Surface's Normal (0) and even you can take advantage of Scale to fit sloped area option. You can find more about these setting in our on-line reference guide.
Also please double check you don't have any Random Translation for Z axis enabled in Transform tab.
Bobby Parker
« Reply #2 on: December 19, 2014, 09:40:20 pm »
Yes, I found the auto slope, thanks!
