Forest Pack => Forest Pro (*) => Topic started by: frodo on December 18, 2023, 03:57:20 pm
Title: Crash when painting area on surface with vertex color modiier
Post by: frodo on December 18, 2023, 03:57:20 pm
in 8.2.5 I encountered crashing when painting area on surface with vertex color modiier. Its random but eventualy it happens every time I tried to paint or erase area. Hope for quick fix thanks.
Title: Re: Crash when painting area on surface with vertex color modiier
Post by: Paul Roberts on December 18, 2023, 04:43:54 pm
Sorry to hear about this issue and thanks for reporting it. Are you using interactive rendering when painting, or does it crash in normal viewport modes?
Best,
Title: Re: Crash when painting area on surface with vertex color modifier
Post by: frodo on December 18, 2023, 04:52:13 pm
Nope Im not doing it while rendering. Maybe there smething else which causing the error but the vertex paint modifier is definitely involved.
Post by: Paul Roberts on December 18, 2023, 04:58:10 pm
OK - thanks for clarifying. I'll look into it and see if I can replicate the problem here. If you can send a scene with the particular setup you are using, that might be helpful too.
Many thanks again for reporting this.
Post by: frodo on December 18, 2023, 05:03:23 pm
I would like to but there are so many connection. Im trying to simplified it as much as possible.
Post by: Paul Roberts on December 18, 2023, 05:04:54 pm
OK - Don't worry. Let me try to replicate it and if I struggle then I will ask you again for more details.
Post by: Paul Roberts on December 19, 2023, 09:57:44 am
I've been doing some tests on a simplified scene here but I cannot currently reproduce the issue with the latests FP and Max 2024.
(https://i.imgur.com/ZC4gpK3.gif)
If you could let me know more details to help reproduce the issue, that would be great.
Cheers!
Post by: frodo on December 21, 2023, 02:57:35 pm
I'm alfo not able to reproduce it with new forest in clean scene so its not propably related only to vertex color map. Im now in a chrismass rush so its hard to do some deep tests :( but its in my todo list :)
Post by: frodo on January 19, 2024, 03:16:09 pm
I still did not figure out why it crashes. There must be something with the scatter items inside. However if I disable vertex paint modifier for vieport only it works.
