Author Topic: Glue Utilities Plugin Not Loading  (Read 3260 times)
Daimon
« on: January 18, 2024, 11:43:08 pm »
Nube here. I'm trying to install the Itoo Glue Utilities Plug-In (glue.dlu) , by dragging the glue.dlu file into the window's viewport, however, it never shows up. I checked in the More section in the Utilities tab and it was not there. I also attempted to run the script in MAXScript, but that didn't work either. Clearly I missing a step here and would welcome any advice.
Thank you!
Kevin
3ds Max 2024.0.1
Forest Pack 8.0.8
NVIDIA GeForce RTX 3080 Ti
32 GB Ram
« Last Edit: January 18, 2024, 11:54:14 pm by Daimon »
Re: Glue Utilities Plugin Not Loading
« Reply #1 on: January 19, 2024, 08:06:12 am »
Hi Kevin,
There is no automatic installer - you will need to install Glue manually by following these steps:
  • Download Glue from here or the Autodesk App Store.
  • Extract the downloaded .zip file.
  • Once extracted, you will find a folder for each supported version of 3ds Max. Open the appropriate plugin folder and select the Glue.dlu.
  • Copy Glue.dlu to the 3ds Max's plugin directory, usually located at C:\Program Files\Autodesk\3ds Max ####\Plugins.
That should help.
Daimon
« Reply #2 on: January 19, 2024, 05:51:25 pm »
Thank you! That did the trick.  :)
« Reply #3 on: January 22, 2024, 08:32:18 am »
You're welcome. I'm glad to hear that it helped. ;)
