Author Topic: nested forest packs  (Read 2967 times)
NN4556
nested forest packs
« on: February 28, 2023, 12:46:38 pm »
I've used FP to scatter some boxes on a wall, and want to use these scattered boxes to scatter plants on them.
However, FP won't work if I use a FP object as a scatter base. I was hoping I could add an Edit-poly modifier on the stack but this isn't possible.
I had to convert it completely into an Editable mesh, and loose all the advantages of a procedural system.
Is there a workaround, enabling me to keep this modular?
cheers,
David
Re: nested forest packs
« Reply #1 on: February 28, 2023, 01:23:07 pm »
Changing the Render Mode for used "nested object(s)" from Automatic to Meshes under the Display roll-out should do the trick.
NN4556
« Reply #2 on: February 28, 2023, 05:12:30 pm »
ok thanks. Will give that a go.
ritoo
« Reply #3 on: March 06, 2023, 06:46:43 pm »
Yep it does the trick. BUT please make it get shown immediately in the viewport out of the box not after running IPR.
