Author Topic: Falloff beyond an exclude spline  (Read 12547 times)
Theo
« on: August 09, 2024, 12:17:51 pm »
Is there a way to adjust a fall off that EXTENDS over an exclude spline. currently the falloff pushes density back away from the exclude spline. is there a way to use negative values so that it leaks into the exluded spline area without having to just shrink the excluded spline and then using falloff normally.
Re: Falloff beyond an exclude spline
« Reply #1 on: August 09, 2024, 12:52:43 pm »
It's not possible to use negative values directly, however, you can achieve the desired effect by duplicating the Forest object and switching the Include & Exclude Areas - by enabling the Invert Curve feature, you should be able to get the result you're looking for.
I hope this helps.
