Author Topic: Replace object in all forests  (Read 6523 times)
CO2263
« on: February 28, 2013, 11:25:09 pm »
I have a huge scene with about 30-40 forest objects. And it's kid of a headache when you need to change one tree type to another. I need to go through all forests and do it manually. Sometimes you can just forgot to make changes to some forests...
Is there any way to replace a proxy for all forest object in one click? If not then would be great to have this feature with new updated Forest Pack version.
Re: Replace object in all forests
« Reply #1 on: March 01, 2013, 10:58:44 am »
The attached script would help you. It replaces the geometry of one object by other, and update names and materials in all Forest objects.
To use it, just set the name of the objects in the two first variables and run it (with the default values, it replaces the "box" by the "cone")
Code: [Select]
-- object that we want to replace
src = $box
-- object that will replace it
dst = $cone
-- processing
instanceReplace src dst
src.name = dst.name
for i in Geometry where classOf i == Forest_Pro do
for n = 1 to i.cobjlist.count do
if (i.geomlist[n] == 2) and (i.cobjlist[n] != undefined) then
i.matlist[n] = i.cobjlist[n].material
i.namelist[n] = i.cobjlist[n].name
CO2263
« Reply #2 on: March 02, 2013, 03:41:17 pm »
Thanks for reply
It works but...
is it possible not to delete the original object instance? Just change it inside forest
any way to have UI for that small script (like pickbutton)
Thx
« Reply #3 on: March 02, 2013, 04:26:57 pm »
Here is. Source is the object that you want to replace, and Target which replace it.
Code: [Select]
rollout forest_obj_replace "Forest Object Replacer"
pickbutton sourceButton "Source" width:140
pickbutton targetButton "Target" width:140
button replaceButton "Replace"
local src, tgt
on sourceButton picked obj do
if obj != undefined do
sourceButton.text = obj.name
src = obj
on targetButton picked obj do
targetButton.text = obj.name
tgt = obj
on replaceButton pressed do
message
if src != undefined and tgt != undefined then
for fo in Geometry where (classOf fo == Forest_Pro or classOf fo == Forest_Pro_3) do
for n = 1 to fo.cobjlist.count do
if (fo.geomlist[n] == 2) and (fo.cobjlist[n] == src) then
fo.cobjlist[n] = tgt
fo.matlist[n] = tgt.material
fo.namelist[n] = tgt.name
createDialog forest_obj_replace
« Last Edit: March 02, 2013, 05:15:24 pm by iToo »
CO2263
« Reply #4 on: March 02, 2013, 04:46:46 pm »
UI works
but 'replace' button does nothing ((
« Reply #5 on: March 02, 2013, 05:17:11 pm »
The script is written for Forest Pro 4, it was necessary to add a small change for Forest 3.
I have updated it, now should work with both versions.
CO2263
« Reply #6 on: March 02, 2013, 05:34:55 pm »
Perfect!!!
Thanks a lot Carlos!  ;)
