Author Topic: Grass Density Question  (Read 3677 times)
Mike123
« on: May 17, 2021, 02:41:59 am »
Hi.I purchased Forest Pro yesterday and I am doing test today.I have a question that I am not sure how to solve it.Pls help.
I used the librabry layered_lawns/Grass Overlay Layer-chickweed to test.
I tried to change the parameter to change the grass density.Pls find my attached.
I changed the map to full,Density to 200cm(min),and changed the Diversity from cluster to random.when I tried to increase the max density, the grass render can't get more density any more.No matter I increased the parameter, it kept the same. What is wrong with me here?Pls help.
Thx!
Re: Grass Density Question
« Reply #1 on: May 17, 2021, 07:42:22 am »
Does it render the same sparse distribution as You showed a viewport screenshot?
ForestPack has two more limits at viewport and at rendertime. You can change them in display Rollout.
Please add more info of what is going on in Your scene and we will help You.
Mike123
« Reply #2 on: May 17, 2021, 11:20:27 am »
Hi Rokas,
Thanks for you reply.
I attached a screenshot pdf file below.Hope this can be more clear for you.
« Reply #3 on: May 17, 2021, 11:39:30 am »
Hi. Would You please attach a max file ?
Mike123
« Reply #4 on: May 17, 2021, 12:06:10 pm »
Hi Rokas,Pls find attached.Thx!
« Reply #5 on: May 17, 2021, 12:16:33 pm »
Thanks!
Ok, this preset has two empty items with high probability. Reduce their probability to increase grass density.
Mike123
« Reply #6 on: May 17, 2021, 12:32:21 pm »
Ah....Yes!!I know.That is why I have this problem.Thx Rokas!
