Author Topic: creeper plants along spline  (Read 3726 times)
KD4391
« on: April 27, 2019, 06:41:44 am »
Hi guys
I have this scene where plants need to be scattered along the semi circle spline.  See screenshot of both front and side.  Problem is, i set it to distribute on path and it doesnt get placed at the right pivot area.  The pivots of the original geometry are perfect so im not sure what is going on.  Also, to ensure the forest object is facing the right way, i need to ensure that the original geometry is also facing the same way.
I can fudge this by moving pivot points and rotating the original geometry but i feel there is a better way?
Re: creeper plants along spline
« Reply #1 on: April 28, 2019, 10:39:01 am »
Hi, Forest aligns the items with the local axis of the own FP object. And the FP local axis depends of the way you created it.
1) If you create the FP object clicking a surface or a spline, FP inherits the local axis of the source object.
For instance, if your spline was created in the Front view, the FP object will be aligned in the front view as well.
2) If the FP is created using the "Icon" mode (without any reference), its axis is aligned with the view where you create it.
So, in this case you can create the FP object in the Front view (using the "Icon" mode), and asign later the spline.
Or if the spline is already aligned with the Front view, just create the FP object using the spline as reference.
