Author Topic: Custom edit  (Read 5257 times)
OG4977
Custom edit
« on: October 03, 2018, 09:47:48 am »
When I use to place individual objects and click in my scene, he creates a tree and leaves the command. I have to reselect the command to insert a tree.
I can not do more than one click.
Have you had the problem already?
Olivier
Re: Custom edit
« Reply #1 on: October 03, 2018, 10:29:01 am »
You mean using custom edit mode?
After placing first tree Your Add option cancels itself? That what You mean? What Version of 3ds max / ForestPack are You using ?
It should work like this:
OG4977
Re: Custom edit
« Reply #2 on: October 03, 2018, 11:16:29 am »
I use Max 2017 and FP 6.12.
That's the function I'm talking about
To place individual objects
    Go to the Create tab in the Command Panel and choose iToo Software from the dropdown list.
    Click on the Forest Pack button.
    Check Mode > Custom Edit
    Click in the scene. Each mouse-click will create a single tree. (is it possible to click several times ?)
    Right-click to exit create mode.
    Switch to the Modify tab for any subsequent edits.
actually the custom edit mode works.
I do not have to use the software properly. :-[
Olivier
Re: Custom edit
« Reply #3 on: October 03, 2018, 11:27:21 am »
I would recommend watching some tutorials to get better grasp of the plugin.
Modern barn would be great tutorial to start. It is for older version of FP but most of the features explained still works the same way.
OG4977
Re: Custom edit
« Reply #4 on: October 03, 2018, 04:31:44 pm »
OK, thanks
Olivier
