Author Topic: Exclude problem with 3.4.1  (Read 9786 times)
PN1828
« on: March 03, 2011, 04:43:25 pm »
I have Forest created with 3.3.  Installed 3.4.1 and opened scene. The exclude spline is not interpreted as 3.3; I get trees where I used to have exclude.  Tried clear exclude and reload exclude spline and get same result.  I am using Max 2008.  Pic attached with exclude spline selected.  Max file attached.
PN1828
Re: Exclude problem with 3.4.1
« Reply #1 on: March 03, 2011, 05:10:58 pm »
Tried with forest 3.4 and get same exclude problem.
« Reply #2 on: March 03, 2011, 06:15:49 pm »
The behaviour of Forest 3.4 evaluating areas is slightly different:
- Nesting level is considered when evaluating the area splines. Nested include splines are used as exclusion zones and viceversa.
We changed it to solve this issue:
http://www.itoosoft.com/forum/index.php?topic=390.0
Splines where multiple areas are nested, may generate a non-logical hierarchy and create unexpected results in Forest.
The easiest mode to remove the nested areas, should be the union boolean operator, in the editable spline tools.
