Forest Pack => Forest Pro (*) => Topic started by: aris_gaddi@yahoo.com on October 05, 2022, 02:33:15 am
Hi There,
I'm using FP7.3.1, I have FP that has static plants together with animated plants. When it's in Generate mode everything is fine, when I stop the test rendering, I can still edit the forest and see the physical forest pack. But when I turn it to Custom Edit mode and press test render, forest pack in the viewport disappear, I can't see anything in the viewport, but it's in the render and still rendering when I start the render test again. But the physical FP is not in the viewport anymore and I can't edit anymore because I can't see it.
PLEASE HELP.
Are you using IR / IPR rendering? If so, please check this tightly related post (https://forum.itoosoft.com/forest-pro-(*)/ipr-fp-7-4-3/msg35212/#msg35212). I hope that helps. Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
