Author Topic: Installing different version to different max versions - same machine  (Read 3974 times)
Morne
I'd like to install different versions, to different max versions on same machine, however I seem not to be able to do this
(This is for both forestpack, as well as Railclone)
Is there a workaround?
Re: Installing different version to different max versions - same machine
« Reply #1 on: October 30, 2019, 04:47:40 pm »
Hi, please take a look at the FAQ entry for Forest Pack. It should have the information you need for multiple versions on the same machine. https://forum.itoosoft.com/forest-pro-beta/install-fp5-and-fp6-for-different-max-versions/
For RailClone 4 you should be able to do the following
  • Install the old version of RailClone first. Just use a regular installation
  • Install RailClone 4, Select advanced installation and choose the versions of Max you with to use with this version.
Please be aware that if we release an update to RailClone 4 and you would like to install it you will need to follow both the above steps again.
I hope that helps,
All the best.
