Author Topic: Plugins causing menu lists to disappear  (Read 3067 times)
PP1809
« on: December 27, 2016, 11:19:21 pm »
New user of Forest Pack and Rail Clone, I installed both plug ins and noticed all my menu lists had disappeared like in the image below. It's happening on all three of my PCs (running Max 2017 SP3) I uninstalled both plugins and the menus started working again, then installed both plugins individually and both are causing the issue. Any ideas how to fix this or will it require a patch?
Cheers!
Re: Plugins causing menu lists to disappear
« Reply #1 on: December 28, 2016, 11:06:00 am »
I can confirm, that this already reported issue - the implementation of FP / RC tool-bars added an empty category to 3ds max's UI (as you can double check, any other Categories aren't affected and can be found in the drop-down menu) has been solved and the fix will be included in next releases.
