Author Topic: Scatter to Edge Problems  (Read 19463 times)
SR1351
« on: May 22, 2025, 09:11:37 pm »
I'm Using the latest 9.2.3 with Corona.  The edge modes do not work correctly no matter what I do. You can see in the picture the much will not go to the end of the geometry. I tried everything, but ultimately wanted to use Edge mode.
Also I had the same issue with using edge mode with the grass in the scene.  It would not cut it to edge until I disabled "Translation under Transform". These issues are really impacting us from finishing the project.
Re: Scatter to Edge Problems
« Reply #1 on: May 23, 2025, 09:57:54 am »
I'm sorry to hear that you're facing trouble with it. Using high values for the Transform > Translation could be causing the issues you're experiencing. To avoid a "grid" appearance with the "Full" map, adjusting the Transform > Translation to around 10-20% usually helps resolve this.
In case of any further troubles with it, as it's really hard to say what's happening exactly in your scene just from the provided image, if possible, please feel free to send us your scene (ideally simplified and containing just this problematic object(s)) to helpdesk@itoosoft.com to check it here. Thanks in advance.
