Author Topic: Daylight system  (Read 3394 times)
Pierre
    • Studiosezz
Daylight system
« on: January 14, 2014, 03:46:11 pm »
I'm using a daylight system with a vraysun . When I try to select the sun in the Shadows/Raytrace/Light parameter , I can not.  This selects the object sky instead. The sun object is not available.
Do you have a trick to solve this problem?
Thank you very much,
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: Daylight system
« Reply #1 on: January 14, 2014, 05:40:14 pm »
The sky object should be fine for this feature. Forest only uses its position, in order to align the shadow planes.
