Author Topic: Deeper sidewalk problem  (Read 5765 times)
Jerny11
« on: December 04, 2017, 05:52:00 pm »
Hi All,
I am trying to make the basic sidewalk deeper ("curb and sidewalk 2" in the library).
I didn't want to use any of the sidewalks under "sidewalks" because of their extra geometry (even though you can make them deeper).
I was able to make the majority of the sidewalk deeper, But run into a problem with the curb cut section. When I make it deeper it pulls away from the sidewalk next to it. I can't quite get them both to move out away from each other to make up the gap.
Anyone have a solution?
Thanks!!
I will attach the file.....
amitgedia
Re: Deeper sidewalk problem
« Reply #1 on: December 05, 2017, 08:03:39 am »
Have you checked with the pivots for the geometry that you are using and the pivot alignment in the RC workflow graphs
Note : if you can provide the attached max file in a lower version like 2015 then i might check on it...
« Reply #2 on: December 05, 2017, 11:36:11 am »
Amitgedia is right. It's the pivots that are causing an issue here. The style uses a little trick to make sure that evenly segments are calculated ignoring the start and end segments in the array. This involves setting the Start Segment's X Alignment to Right, the End Segment's X Alignment to Left and then adding generator padding to the start and end the same size as the segments. I've fixed your style in the attached Max file.
All the best,
