Author Topic: Pressed Grass  (Read 12272 times)
leejk
Pressed Grass
« on: July 14, 2024, 03:59:31 am »
Is it possible to make a depressed area in a grass distribution so that it appears as if a vehicle just drove across it? Maybe I'm wrong, but thought I saw this in a monthly video before but can't seem to find it now or I imagined it. :)
thx
Re: Pressed Grass
« Reply #1 on: July 15, 2024, 10:57:52 am »
Thanks for the question, you can use the Scale By Spline Forest Effect for that purpose. There's a little bit of information and a demo about it in this livestream (at minute 42).
I hope that helps,
leejk
Re: Pressed Grass
« Reply #2 on: July 15, 2024, 07:47:37 pm »
That was it! Thank you sir!
leejk
Re: Pressed Grass
« Reply #3 on: July 16, 2024, 07:40:19 pm »
I am having a bit of trouble getting the desired effect with this technique. The "path" thru the grass is too jaggy and there is a "cap" at the end of the spline. I'm using the large patch preset for grass... is that the reason?
Also, not sure I visualize what the curve and falloff parameters do. It seems like to me I should not need a falloff distance at all since the curve shape resembles a U shape.
