Author Topic: Delete Selection (more than one item) from Library  (Read 7211 times)
MK3983
« on: November 08, 2017, 03:38:00 pm »
Hi Guys,  :)
Not sure if it exists or has been requested again. Although i've been looking for the past hour and it seems to be missing.
Is there a way to delete more that one item per time in Library... i removed few files from the folder and they keep appearing in the library...
i don't mind having them there but i takes la lot of time to load so.. is there a easiest way than going one by one manually?
Best Regards
idnok
Re: Delete Selection (more than one item) from Library
« Reply #1 on: November 10, 2017, 08:39:03 am »
Hi, unfortunately the Library Browser doesn't support multiple delete.
We have plans to rewrite this tool completely. For this reason we have not improved it lately.
For massive editing, we usually modify the "index.xml" file directly. It has an understable format, and can be editor with any text editor.
There is an index.xml by library. To locate it, use right click menu->"Open in Shell" with any library selected.
