Author Topic: Distribution Reference Mode  (Read 4402 times)
Klonsemann
« on: March 06, 2020, 10:44:11 am »
When generating trees at pivot position from multiple splines that come from architectures plans.
Is there a way to tell FP to use a specific geometry ID (other than 1) ?
Spline-MaterialIDs or ObjectIDs seem not to work.
We currently switch to "Custom Edit Mode" to set a different ID from the geometry list.
We also know the trees interface and setGeomID, but we want to avoid to switch to "Custom Edit Mode"
Re: Distribution Reference Mode
« Reply #1 on: March 09, 2020, 10:39:56 am »
Sure, even when working in the Generate mode, you can "Select models" for each Area - in the Select models window, you can Pick the desired item(s).
