Author Topic: How do I remove Forest permision to delete server content  (Read 11835 times)
MartinMHulse
« on: January 13, 2025, 05:21:44 pm »
I am trying to restore custom libraries after PC re-build and the new Forest has the plant libraries listed on the left hand side of the dialogue box, but it is actually the original folders, I deleted a folder as it had no content shown and the files have diappeared from the server. Not into the recycle bin but gone lost for ever, who thought that was a good idea?? How do I remove this facility as it is far to dangerous to leave as it is?
Re: How do I remove Forest permision to delete server content
« Reply #1 on: January 14, 2025, 09:13:05 am »
Hi Martin,
I’m sorry to hear about the issue you’re experiencing. To avoid this problem, the safest approach is to adjust the folder permissions in your system. Alternatively, if you want to "lock" the library from being edited within the Library Browser, you can add the
Code: [Select]
readonly="1" tag to the header of the corresponding index.xml file in your library.
