Forest Pack => Forest Pro (*) => Topic started by: CI3736 on August 01, 2019, 01:59:29 am
Title: Density & scale curve edits in the Falloff menu not saved when saving presets
Post by: CI3736 on August 01, 2019, 01:59:29 am
Apologies if this issue has already been raised.
In the Falloff (global props) rollout menu, there are 2 edit curve buttons.  Any changes made to these curves are not saved when you save a preset in the General rollout menu.
This seems like a bug that has an easy fix.
Am I missing something?
Thanks.
Title: Re: Density & scale curve edits in the Falloff menu not saved when saving presets
Post by: Rokas on August 01, 2019, 08:52:06 am
Not all values are saved when using presets. Please note that.
For most uses this feature has been superseded by loading and saving presets via the Forest Library, however it remains useful as a quick way of copying settings between Forest objects and setting defaults values.
