Author Topic: Fast paint  (Read 3160 times)
RealViz
    • RealViz
Fast paint
« on: July 31, 2019, 09:46:40 am »
now we work on very large project and painting is madness. It possible tu make feature/button to "Fast paint"? I found that if you deactivate active paint Area (On is unchecked) and I activate "Freez ALL Forest obj." I see area what is painted (spline) but not see trees etc. .. The advantage is that painting is extremely fast and accurate.
If there a button to "Fast Paint" these feature will active while painting (mouse down) and refresh only when stop paint (mouse up).
Re: Fast paint
« Reply #1 on: July 31, 2019, 11:37:22 am »
Thanks for suggestion, added to the development list.
For large projects, other workaround is to create separated areas, and join them once completed. It's a bit more efficient, and may disable temporary areas which you are not working on.
RealViz
    • RealViz
Re: Fast paint
« Reply #2 on: July 31, 2019, 12:47:46 pm »
Yes spliting to areas, disabeling etc. is OK. But not so user friendly. And its not working when FP is used as exclude for another FP.
edit: thanks for adding to TODO dev.
