Author Topic: FP6 effects - Density by Map - Only 1 map channel?  (Read 3398 times)
SnipeyX
« on: July 30, 2018, 09:57:56 pm »
I can only get the "Density by Map" effect to work on map channel 1. Even if I set the texture map and corresponding UVW Map modifier to map channel 2, it displays with the map channel 1 coordinates.
Bug/wish list item or am I missing something? Max 2019 sample file attached. Checkerboard only moves when i set the modifier to map channel 1 even though the texture is set to map channel 2.
Re: FP6 effects - Density by Map - Only 1 map channel?
« Reply #1 on: July 31, 2018, 08:49:30 am »
Thanks for suggestion. Added to consideration list.
Sebastian
« Reply #2 on: August 02, 2019, 07:25:56 am »
Anything new about this? Seems as currently Areas->Surface Area->Distribution Map has the same problem (6.2.2) Had to rework complex material und UV assignments to push everything up one level ...  :-\
