Author Topic: Detached Object doesn't show Forest.  (Read 4414 times)
CH3810
« on: June 19, 2018, 05:35:50 pm »
On the attached file. These are objects that have been detached as clones of a larger object. When I click to add a forest lawn to them there is a message saying "To use large areas it's recommended to use Camera > Limit to visibility. Do you want to enable it. Do you want to enable it.
I click yes then nothing appears in the viewport or render.
When I render I get the message:  The density of the items has reached the "Max Density" limit.
Only when I attach one of these objects to a plane I create can I get any Forest to show in the viewport and renderer
Re: Detached Object doesn't show Forest.
« Reply #1 on: June 20, 2018, 09:50:17 am »
Are You talking about surface objects?
Please reset  xform and You will be able to use them correctly:
CH3810
« Reply #2 on: June 28, 2018, 04:02:30 pm »
Thank you.
