Author Topic: Detailed explanation for getting shadows with custom billboards and Vray?  (Read 5650 times)
danb4026
Cannot find a detailed tutorial on getting shadows with custom billboards and Vray.
I am creating a crowd of people using Vray and Vray materials with opacity maps.
Any explanation would be appreciated.
You can find an (old) tutorial for billboards shadows here:
http://www.itoosoft.com/forestpack/tutorials/tutorial_shadows.php
Basically, this should be the procedure using VRay:
1) Put your VRay material in the Base slot of a new Forest Material
2) Assign it to Geometry->Geometry List->Material
3) Assign the main light (as VRaySun) to Shadows->Raytrace->Light
The following FAQ entry regarding billboards also may be useful for you: http://www.itoosoft.com/forum/index.php?topic=448.0
« Last Edit: January 07, 2013, 10:14:06 pm by iToo »
danb4026
Thanks very much!  I will give that a try.
danb4026
Do you turn fake shadows off?  What about the checkbox for "xshadow/raytracing"?  If that is left off, I assume that you do not check "Cast opacity mask for Custom Objects"?
In the "Raytrace" Dialog, I understand that you choose your light (sun in my case), check "Hide planes on viewport, check "prevent self shadow" and uncheck "every tree over itself"?
Thx
Fake shadows must be on, in order to generate the shadows for the billboards.
Regarding the other options, default settings should work fine (use the screenshot of the help as guide):
http://www.itoosoft.com/forestpack/reference/refshadow.php
You can see the description of each parameter in the same page.
