Author Topic: more density = empty render  (Read 3390 times)
ldotchops
« on: December 14, 2023, 01:15:04 pm »
I am scattering objects and i need to make them incredibly dense, but once i go below a certain threshold my render is blank and they dissapear. Max density is at 999 mil but they don't show up. image is on full.
Re: more density = empty render
« Reply #1 on: December 14, 2023, 01:26:53 pm »
When facing this kind of issue, you can check more details under the General > Forest Stats window. It should give you a hint of where the problem is. In the case of big areas or high density, you may reach the Max items / Max faces for viewport / render limits, and you may need to increase some of them. Since the Forest Pack Pro/Lite 5.0.5, "All scattering limits (Distribution > Max. Density, Display > Max Items/Faces) can be disabled by setting the value to zero." It's also possible to set them from Maxscript in the following way:
$.maxdensity = 0
$.vmaxitems = 0
$.rmaxitems = 0
$.maxfaces = 0
Please feel free to have a look at this related post regarding the error message ("Some forests were not built correctly in the last render").
