Author Topic: Disappear some bush  (Read 6741 times)
Alex
Disappear some bush
« on: March 01, 2012, 10:59:08 am »
Hi all, i've have a problem with forest pack 3.8:
i made a bush with custom edit creation (click on scene to create trees) and than i go to modify panel select trees edit mode, i select my single bush and i duplicate it with standard 3ds mode (shift + move). The problem is that, when i reopen the scene, some of bushes (70% more or less) disappear, appear only when i go to modify panel and return to trees edit mode, but when i close tree edit moden they disappear again, in viewport and render too.
Anyone could help me?
Thank you and sorry for my english :P
Alex
yuv
  • iToo Software - CEO
    • Itoo Software
Re: Disappear some bush
« Reply #1 on: March 01, 2012, 11:30:05 am »
Probably you have active some of the render optimizations as the camera view restriction, please try to uncheck in the Camera rollup the "Limit to Visibility" option:
http://www.itoosoft.com/forestpack/reference/refcamera.php
In other hand, if you have a high number of elements (tens of thousands), the viewport is hiding some of them to improve redraw speed. To check the settings for viewport see the Display rollup:
http://www.itoosoft.com/forestpack/reference/refdisplay.php
If these solutions doesn't solve the problem, please tell me for further checkings.
Daniel Quintero
Itoo Software
www.itoosoft.com
daniel@itoosoft.com
Alex
« Reply #2 on: March 02, 2012, 10:45:51 am »
Great, it was le "limi to visibility"
thank you so much
Alex
