Author Topic: Reduce RAM usage  (Read 5290 times)
Richard Birket
Reduce RAM usage
« on: September 22, 2015, 10:03:02 am »
We are having quite a few issues with v4.4.1 where we get excessive hanging at the end of a render and also various crashes. The scene is quite heavy with a lot of grasses and flowers and a few trees.
The RAM usage when rendering is beyond 20GB. What methods should we be using to reduce the amount of RAM? Are there some general tips? I had hoped that only the geometry in each bucket would be loaded into memory but given 20GB+ I am thinking not.
A checklist would be useful - for instance, is using VRay Proxies a good idea, or using Brute force, or IRmap better or worse.
Kind Regards,
Rich
www.blinkimage.com
Richard Birket
Re: Reduce RAM usage
« Reply #1 on: September 22, 2015, 10:30:35 am »
It looks like our problems might be related to the XREF scene issues pointed out by Peter Guthrie in another thread. I have added a comment to that thread.
Kind Regards,
Rich
www.blinkimage.com
« Reply #2 on: September 22, 2015, 10:31:41 am »
Would you please save and send us the minidump file of the crash? (You can get the minidump clicking "View report details->View report contents", checking the path of the "3dsmax_minidump.dmp" file and making a copy of it, before closing the 3ds Max Error Report window). Hopefully, it'll point to the problem source.
Please specify which 3ds Max / renderer releases are you using. Thanks in advance.
As mentioned in the Rendering Best Practice section of our on-line reference guide:
"To render high-poly objects or proxies, increase the Dynamic Memory Limit from the default value to a percentage of your total RAM. The optimal value depends of the complexity of the scene, but usually a minimum of 2000 or 3000 Mb. is required. In V-Ray 2.0 and later, you can set this to 0 to remove any limit in that case, V-Ray will take as much memory as needed."
I would suggest you to check this "Should i use meshes or proxies with Forest in V-Ray?" post regarding proxies / meshes advantages.
Hope you'll find it useful.
