Author Topic: error on using library  (Read 5855 times)
MQ4267
« on: September 08, 2017, 11:25:03 pm »
hello. i'm getting the attached error in 3ds max 2017 upon loading a custom library object(s) that i created.  i created the library object in max 2017 if that makes a difference.  despite getting the error, all seems to be OK, meaning i can render, adjust material, all properties within forestpro etc...
thanks,
edit:  ok, so what happens is, i select forestpro, then click a surface (a plane which is usually an editable poly), then click on library. i go to user library, select what i created (it's grass, like a lawn with 1 multi/sub material and 1 regular material) when i double click to select the library object, or if i highlight it and click ok, the library window closes and i'm returned to 3ds max and the error pops-up.
thanks,
« Last Edit: September 08, 2017, 11:27:46 pm by MQ4267 »
Re: error on using library
« Reply #1 on: September 11, 2017, 11:18:17 am »
Would you mind to send us that problematic part of your library (including .max file(s) and the index.xml), to check it here? Thanks in advance.
