Author Topic: Vray scattered lights not rendering  (Read 2938 times)
Javier G
« on: July 03, 2023, 11:46:07 am »
I am trying to experiment with the scatter lights function for the first time, it seems to be not working.
I am scattering some vrayLights in a test scene. I have trying scattering them on a path or through reference mode. In any case, scattered light appear correctly in the viewport and the FP object doesn't display any warning or error.
Despite that, when I hit render, no light appears in the scene. Lights only work if I instantiate them, but then I lose the parametric properties that I would like to keep. I have been trying to fiddle with all the options, but I can't understand what I'm doing wrong.
I'm using the lastest version of FP, and Vray 5 Update 1.2. Could it be a matter of Vray not being updated to the latest version?
I am attaching a screenshot of scene + setup, hopefully it helps. Thanks!
« Last Edit: July 03, 2023, 12:02:57 pm by Javier G »
Re: Vray scattered lights not rendering
« Reply #1 on: July 03, 2023, 12:17:22 pm »
Hi Javier,
The "support for native light instancing in V-Ray" requires the V-Ray 5.2 or greater, Updating to the V-Ray 5, Update 2 should help.
Javier G
« Reply #2 on: July 03, 2023, 01:00:55 pm »
I suspected as much.
Thank you for the quick reply!
Best regards
