Author Topic: Switch to Custom Edit Mode with Z transform translation change trees offsets !  (Read 3618 times)
TATMathieu
I use the z transform (translation) to set up my forest. And when I switch to custom edit to tune it, every trees change Zoffsets !
I've find some issues, but changing about version and setup...
For Right Switching to custom edit :
3dsMax 2021   Forest 6.3.1
if Link to surface is ON
Have to /2
Script :
$.mode = 1
$.transzmin = $.transzmin/2
$.transzmax = $.transzmax/2
if Link to surface is OFF
Have to /100
Script :
$.mode = 1
$.transzmin = $.transzmin/100
$.transzmax = $.transzmax/100
3dsMax 2022   Forest 7.4.3
Link to surface   ON   → Ok
Link to surface   OFF
Have to Set to 0
Script :
$.mode = 1
$.transzmin = 0
$.transzmax = 0
and the limitation of using integer only is not very user friendly for fine tuning.
Thanks.
Thanks for reporting this, we'll look into it although for obvious reasons we wouldn't be able to change the FP 6 branch.
Until then, you might be interested in using Forest Effects. It would be quite simple to add a Forest Effect that allows you to change the Z Offset in scene units instead of a percentage. And in my tests it also doesn't appear to be affected by the Link To Surface options.
« Last Edit: August 22, 2022, 03:05:04 pm by Paul Roberts »
