Author Topic: Display not working properly "Firepro V7900"  (Read 5561 times)
NL2911
« on: May 30, 2012, 10:14:55 am »
Since my new workstation with a Firepro V7900 the display of the Forest pro is horrible.
 It doesn't match the settings i have in forest pro (include / exclude, distribution, etc)  Trees shows up  on surfaces where the don't have to. I have all kinds of strange dots all over the scene...I have to render to see the result.
Is there a workaround? some videocard settings maybe?
Thanks in advance
Re: Display not working properly "Firepro V7900"
« Reply #1 on: May 30, 2012, 10:58:15 am »
Does it happen with all Display modes or only using Point-Cloud ?
Please, try turning off "Use DirectX acceleration" in the Display rollout or changing the viewport mode (as Pyramid or Box), and tell me the result.
NL2911
« Reply #2 on: May 30, 2012, 11:47:09 am »
Wrong display in proxy, pointcloud
That fixed it! Thanks!
I still see some points in the scene (using point cloud) where they don't belong, but only a few. I will do some more longterm testing see if its on every scene or this scene particularly. But for now thnaks!
« Reply #3 on: May 30, 2012, 11:58:24 am »
Theorically the proxy mode should be exact, because it generates a standard mesh for the viewport. If not, we should get a test scene and compare.
The DirectX checkbox is used only for Point-Cloud. When on, Forest uses an optimized routine to draw the points, but it seems this mode is not compatible with all cards.
