Author Topic: Forest color by element problem  (Read 3008 times)
DrunkenMaster
« on: December 12, 2018, 12:24:20 pm »
Hi, I need help.
I need to create Football pitch, using forest color map.
I have a texture on a surface, and checked get color from map, it works ok but i wanted to change clolor of individual elements instead of items, So it looked nice and cleen. White lines on the picture should be straight and sharp...
Is it posible..?
I know i can use smaller scatter object, but i dont want to do that...
Thank you
Re: Forest color by element problem
« Reply #1 on: December 13, 2018, 02:23:33 pm »
It is not possible to get color from surface by element.
As a workaround You can use this technique. Hope this helps.
