Author Topic: Material optimizer problem  (Read 3886 times)
manel_reig
« on: July 19, 2021, 08:26:06 pm »
when I try to use the "Optimize Materials" tab on the Material section of a FP, it apllies the forest color on the materials, but sadly it also randomizes the materials between the objects inside the forest pack.
Is there a way to avoid this? the feature is kind of useless this way... :'(
thank you
Re: Material optimizer problem
« Reply #1 on: July 20, 2021, 10:00:02 am »
I'm not currently able to reproduce this here. Would you be able to attach a stripped scene (just the FP object) that gives you the wrong results. Preferably saved before running the material optimizer. You can send it to helpdesk@itoosoft.com if you'd prefer not to share links publically.
Thank you,
