Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Forest pro 3.6 icon disable ?
« previous
next »
Print
Pages: [
1
Author
Topic: Forest pro 3.6 icon disable ? (Read 8376 times)
UI3053
Newbie
on:
September 04, 2011, 04:24:41 pm »
hi !
i have a pb with my viewport in 3dsmax 2012 vray 2.0
i cant see the icon to select my forest element , i tried to change the scale... but nothing work...
so... i must to select my forest element from the layer panel from max.
sorry for my bad english.
ben
Logged
Administrator
Hero Member
Re: Forest pro 3.6 icon disable ?
Reply #1 on:
September 04, 2011, 09:32:52 pm »
The icon is displayed only when there is an error condition, with no items built. On normal conditions, you can pick the Forest object clicking directly on it.
Logged
UI3053
Newbie
Reply #2 on:
September 05, 2011, 04:08:55 pm »
hi and thanks for your answer.
yes... i think there is an error... i tried to change the 3dsmax's viewport drivers, direct 3d, nitrous, opengl.... but nothing work.
i will check if there is something wrong with my cg drivers.
thanks again.
ben
Logged
Administrator
Hero Member
Reply #3 on:
September 05, 2011, 04:32:50 pm »
Ok, but can you see the items created by Forest or is the object empty ?
Remember that you can check the errors conditions on Forest, clicking the "Stats" icon ("General" rollout).
Logged
UI3053
Newbie
Reply #4 on:
September 05, 2011, 06:20:13 pm »
yes, i can see the items in viewport and render, its just the icon dont appear...
so it's not a big problem, i can do without.
thanks
ben
Logged
Administrator
Hero Member
Reply #5 on:
September 05, 2011, 06:34:56 pm »
Yes, that's normal. The icon appears only where Forest cannot build any item, usually because there is not area defined, the density is too high or whatever issue. When this happens, you can see the description of the problem in the "Stats" window.
Logged
UI3053
Newbie
Reply #6 on:
September 05, 2011, 08:47:55 pm »
ok !
thank you for your help and sorry for my stupids questions
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
