Author Topic: Material Optimizer  (Read 2710 times)
JM2145
Material Optimizer
« on: July 28, 2021, 08:52:17 pm »
Is there any way to change which checkboxes are ticked by default when launching the Material Optimizer.  I only ever use it for 'Modify Custom Objects Materials' and 'Apply Forest Edge', it would be great if I could edit a file so those two were the only things ticked when I launched it
Re: Material Optimizer
« Reply #1 on: July 29, 2021, 09:39:09 am »
Thanks for the question. The version of the material optimiser in the latest version of Forest Pack should be saving its settings into an .ini file so the it remembers your previous settings. The file will be saved here: C:\Users\[username]\AppData\Local\Autodesk\3dsMax\2022 - 64bit\ENU\scripts\forestpack
In earlier versions I'm afraid settings were not remembered.
I hope that helps,
JM2145
« Reply #2 on: July 29, 2021, 10:40:25 am »
Perfect, I better update then :)
