Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
How to delete forest in scene
« previous
next »
Print
Pages: [
1
Author
Topic: How to delete forest in scene (Read 5918 times)
MS4538
Newbie
on:
April 13, 2014, 05:44:43 pm »
Hi, I have created some forest in the sence( in layer there has forest 001 to forest 015), I wish delete forest 003 to forest 015, how to do that ? when select forest 003 ( or other ) in the view, I can't delete it by press delete key...
Logged
ITOOSOFT
Hero Member
Re: How to delete forest in scene
Reply #1 on:
April 14, 2014, 09:40:33 am »
all Forest objects can be deleted in the same way as any object in 3D Max (by
Delete
key). Probably the most efficient way is through
Manage Layers...
window. You can do multiple selection using
Shift
or
Ctrl
key and then
Select Highlighted Object and Layers
. Please check attached screenshot.
If you hit
Delete
key and nothing happens please double check if the object is not frozen or in frozen layer.
Selection Lock Toggle
activated (by default assigned to space key) will block your selection so please double check also this option.
Please note that once working in
sub-mode
of Forest object to delete it you'll need to exit this mode (this behaviour is similar as working in sub-mode of any mesh object in 3D Max). Attaching screenshot showing this mode.
Hope this tips will help you with this trouble.
Kind regards,
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
