Author Topic: distribution map  (Read 2952 times)
djibvongenf
distribution map
« on: May 15, 2022, 04:11:58 pm »
Im having a precision issue with a distribution map. Any idea why the grass preset does not follow the border (in yellow)?
Distribution map is B/W of 10k pixel.
thank you
« Last Edit: May 15, 2022, 07:14:57 pm by djibvongenf »
RealViz
    • RealViz
Re: distribution map
« Reply #1 on: May 16, 2022, 08:00:52 am »
It is much better to use edge mode for this.
https://www.itoosoft.com/tutorials/edge-mode
djibvongenf
« Reply #2 on: May 16, 2022, 08:18:50 am »
Hi,thank for the reply,
Unortunately the ground is not flat :(
RealViz
    • RealViz
« Reply #3 on: May 16, 2022, 08:29:40 am »
It doesn't matter. Just put the object in surface and check edge mode in area spline. Or split the surfaces themselves with shapemarge and then check edge mode in area and enable in surface area.
djibvongenf
« Reply #4 on: May 16, 2022, 10:29:17 am »
Once again thanks a lot cause it works amazingly.
