Author Topic: mirror tree in sub object level  (Read 4221 times)
mikegentile
« on: May 14, 2014, 11:21:23 pm »
hi all-
i'm using forest pro to place hundreds of houses on a site. my client has provided me with a specific layout. one of the floor plans of the house is an "L" shape. how can i "mirror" the plan in the subobject of the forest object?
-mike
Re: mirror tree in sub object level
« Reply #1 on: May 15, 2014, 10:57:40 am »
There is Enable Horizontal Mirror option under Transform tab - Mirroring. Please check attached screenshot.
But as it's calculated on random base probably in your case you should use another workaround. Mirror please the source Custom object and add it to your Geometry list inside Forest object. Now while placing in Tree Editor - Custom Edit mode you can choose the Model - original or mirrored. Hope this helps you. Attaching screenshot showing also this workflow.
Kind regards,
mikegentile
« Reply #2 on: May 15, 2014, 07:39:23 pm »
thanks. in this case i'm using a second mirroed source object
-mG
