Author Topic: Distribution map not filling whole area  (Read 3367 times)
iCreateLtd
« on: July 21, 2016, 11:56:34 am »
Hi.
As you can see from the image, forest pack is not filling the whole distribution map I've made.  Can you tell me how to fix this?
A mistake I made in the past was that I had limit to camera turned on.  I've got that turned off and it still isn't working.
Re: Distribution map not filling whole area
« Reply #1 on: July 21, 2016, 12:23:51 pm »
It's hard to say just from provided screen-shot where the problem could be. Would you mind to send us your scene to check it here? Thanks in advance.
iCreateLtd
« Reply #2 on: July 21, 2016, 01:21:26 pm »
Sent the file.  The whole scene would be too big so have only sent the essentials.  If you need more, let me know.
« Reply #3 on: July 22, 2016, 10:42:03 am »
Hi Sean,
Thanks for provided scene. It's because of the Forest object rotation by 90º - to get the correct distribution it can be easily fixed by setting 0º. As the distribution is very dense you'll get a warning message and you should raise the Max density limit or lower the actual Density values.
Hope that helps.
Best regards,​​
